data logged the 383 who wants to see it??
data logged the 383 who can take a quick peek and HELP diagnose it
will with the on going problems of this car i was wondering if anyone wanted to see the datA WE GOT TO day and share there input!?
lol well im actually asking if someone who knows about lt1s if they can check it out thanks though haha.
its really weird we are getting 5.0 of knock retard at idle and even at WOT is this because we have solid motor mounts?? it says the left o2 has failed and the right one is rich! always something with this car!
i coulnt tell you...what did you think of the datalog? my buddy told me he doesn't think the heat senor ground is hooked up to the o2s
i couldnt view the log on my computer..however the things you should focus on are what plugs you are using, o2 sensors and the wiring if there are extensions. also, check the maf to see if its clean..vac leaks. you have to fatten up the fuel mixture on it..injectors and fuel pump/filter are also things to check.
