what studs came w/ RR on LT4 hotcam kit?
Originally Posted by eLTwerker
Did 3/8" or 7/16" studs come w/ LT4 hotcam kit? On a side note are LT4 hotcam kits all the same?
The factory rocker studs are 3/8" -- It is suggested to swap over to 7/16" studs when you get into higher lift cams just so you don't risk the factory sized studs being too stressed
changing rocker studs requires new RR though, right? Also, what does going to bigger than factory requre as far a moding? Drilling out the holes bigger to accept the new studs? Anybody know where to buy 7/16" studs and how much they cost? Thanks!
