what head gasket for my 383 with nitrous
Old 02-12-2007, 09:13 AM
cgworth's Avatar
Default what head gasket for my 383 with nitrous
whats a good head gasket to use on my LT1 383 stroker , i plan on shooting 150 shot of nitrous, heads and block are NOT decked
several suggestions and part numbers would be apreciated
flat top pistons and stock heads with 5 angle valve job 1.6 rr gm 847 cam
i would also like to be between 10.5 to1 to 11 to 1 compression ratio
Old 02-12-2007, 09:48 AM
96capricemgr's Avatar
piston and chamber specs?
Since you are going to have horrible quench I think most of us would like to tell you THIN gaskets but before we do that we should know some more specs so we do not endup causing compression to get too far out of hand.
Old 02-12-2007, 10:14 AM
cgworth's Avatar
bored .30 and stock head with 5 angle valve job, flat top pistons i know i know but i didnt have enough to get the heads ported , i will have to do that later, i would also like to be between 10.5 to1 to 11 to 1 compression ratio
Old 02-12-2007, 02:40 PM
cgworth's Avatar
ttt..
Old 02-14-2007, 02:56 PM
cgworth's Avatar
ttt..
Old 02-14-2007, 03:22 PM
1997bird's Avatar
Mr Gasket CO. part # 5716 is a pair of Ultra Seal head gaskets that are good to 12.1:1 compression. They have a 4.110" bore dia and have a 0.026" compressed thickness.
As for you compression ratio its hard to tell. I have had stock casting "327" 2 bolt LT1 blocks with varrying deck heights on all four corners. Personally I would not even put the motor together until you have had it decked (locally it only costs $175). Like 96capricemgr stated your quench is going absolutely horrible.
Quick Reply: what head gasket for my 383 with nitrous
