Need Help In Instalation
Old 02-13-2007, 07:48 PM
BLACKSHARK's Avatar
Default Need Help In Instalation
Need step by step instructions for convertion from stock 1.5 rockers to 1.6 summit roller rockers.It is an lt1 1994 z28 t56.any help would be appretieated. Please be as detailed as you can be.
Old 02-14-2007, 12:53 PM
raroz28's Avatar
http://shbox.com/ci/valve_spring_swap.html
It's really as easy as it looks. Unbolt the rocker and pull it off. Just be sure to adjust the valve lash when you bolt the new rocker on.
Old 02-14-2007, 01:12 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Spring swap is highly recommended. Don't skimp
Old 02-14-2007, 08:25 PM
9formula4's Avatar
you need springs, retainers, locks, rockers (self aligning). If you go with non self aligning you need guide plates and hardened pushrods.
Old 02-15-2007, 02:17 AM
sssalah's Avatar
And if the rockers are not narrow body (for the center bolt valve covers) then the valve covers need midification.
Quick Reply: Need Help In Instalation
