LT1 Corvette engine cover on Z???
Have you tried em yet? I've seen em several times and was under the impression they bolt right on. I don't think there's any differences in the vette LT1 except maybe the exhaust manifolds.
They will fit, try putting them on.....I belive you have to cut down the back a little bit to clear the fire wall but im not sure.
People put them on because it makes the engine bay look nice for Fbodies.
You will have to clearance them in certain areas - mainly around the fuel lines. You will also have to get the mounting pins that screw into the manifold, if you didn't pick them up.
