400hp?
Old 02-14-2007, 10:41 PM
Lt1CamaroSS's Avatar
Default 400hp?
i have a 94 lt1 a4..i want to make 400+hp without spending a ton of money...i dont want a power adder yet...what are your opinions on what i should or shouldnt get..thanks
Old 02-14-2007, 10:48 PM
95FbFormula's Avatar
You could get an LE2 set-up and run stock bottom end and possible a new stall and a tune. also some supporting mods like headers, could be all done for about 2K to 2500, or you could get a 150 shot of nitrous for 1K and be set.
Old 02-14-2007, 10:51 PM
if i do a full bolt on plus a tune and stall how much hp am i looking at
Old 02-14-2007, 11:38 PM
SShawn's Avatar
low-mid 300's ide guess, i made 280's with exhaust and cold air, but the car had a miss so...idk how accurate that is
Old 02-15-2007, 12:02 AM
I8ASaleen's Avatar
You're looking at low-low 300's. To get what you want to the wheels do all the boltons and 100-shot (which is what I'm in the process of doing)
Old 02-15-2007, 07:10 AM
CALL911's Avatar
Bolt ons won't get you much over 300. The cheepest way to get you to 400 RWHP is to put together a killer heads and cam combo (+ have all the supporting bolt-ons such as headers).
The GM847 cam is a monster. Take that with a great set of TFS heads ported by LE, and you probably should be in the ball park of where you want to be.
Old 02-15-2007, 10:16 PM
donkey mule's Avatar
The cheapest way to get there is NOS. Cheapest is not always best.
Old 02-15-2007, 10:25 PM
95 Camaro Z28's Avatar
400 hp isnt **** with out the suspension to put it to the ground. so if you want to do more than sit and spin with 400hp, u will need to invest in suspension as well.
as for reaching that number heads and cam with supporting mods is a great way to go.
in my case a 383 stroker with mild head and intake work with a decent sized cam with typical bolts on and stuff is right at 400 rwhp
