need help...
need help...
got my plugs done at a friends shop but i ended up with a extra wire...they ar e the msd super conductor wires..after that it has been misfiring and heatin up...can that wire be the result or maybe wires are not in right place? or that wire? im guessin the old one is still there but have not checked?...the wire is different then the one you hook up to spark plug and opti..it has black terminals and it came with the msd wires...does anybody have a diagram or picture where the sparks plug wires need to be? thanks
that wire is probably the one that goes to the coil. maybe its misfiring because one of the wires in touching the header and got burnt, check the wires. also check the plugs wen i put mine it they came on getting loose had to tighten them 2 more times after installing them
Originally Posted by 1slot/a408
thanks....its weird becuse when it misfires it looses all its power but then it gets it back and does the same again..you have any idea?
