Rear end...AHHHHHH
Old 02-19-2007, 05:20 PM
grnmonster's Avatar
Default Rear end...AHHHHHH
things breaking on my car is getting old fast...anyways when im driving i here like a clanking noise while im in gear and when im out of gear and just coasting it still makes noise but not as bad i can defanatley tell its from the rear of my car...could my rear end be going ou???? i hope not i cant afford this anymore
Old 02-19-2007, 05:31 PM
boomtubes05's Avatar
you may have chipped the ring rear pop the cover off and check both of the gears
Old 02-20-2007, 10:36 AM
1997bird's Avatar
Check your driveline u-joints as well, they will make a clanking sound when the needle bearings come out of the cap of the u-joint.
Old 02-20-2007, 06:11 PM
hi officer's Avatar
i broke two teeth off the pinion and mine sounded pretty much the same
Old 02-20-2007, 08:41 PM
blk97z28's Avatar
how hard is it to check the drilvel ine u-koints just jack up the car and get under there and look?
Old 02-20-2007, 08:53 PM
grnmonster's Avatar
yea your right imma take a look tonight
grnmonster's Avatar
appreciate the advice
Quick Reply: Rear end...AHHHHHH
