lt1 headgasket
lt1 headgasket
i just bought a 97 t/a with a blown head gasket and was wondering how hard are they to change.there was no water in the oil so the bottom end is still good.i know i should change the cam while i have it apart and probably will do that what i want to know is can you pull the heads off and put them on with out pulling the motor i know it will be a pain in the a$$ but dont have time/room to pull the motor right now if i dont have to. any help and tips are greatly appreciated
Originally Posted by zlover129
It can be done, easily honestly...well not easily but its far from impossible. Just kind of tight working in the engine bay but yea, definitely doable
yaeh was also planning on LT's. i pulled the intake and heads off my 93 bird before i found out i had more problems than just the top end (bent rod) so i pulled the rest of the motor just didnt know if there was enough room to put them back on like getting a torque wrench in there thanks. any tricks you know of or is it just pretty much go at it?
