lt4 springs and rockers
you will probably need all new stuff man. those springs are barely big enough to handle the hot cam and have a max lift of .525, and the 1.6 rockers are only good to .575 lift which if i'm not mistaken you will be above correct?
Originally Posted by kline454
yeah the rockers are good, for .575 they work good on cc306 thought,
yes that is true but a cc306 is right at the max as it's max lift is around .576 (which i would still be a bit weary as i do not like to live on the edge when it comes to my valvetrain)
a gm847 with 1.6 lift is around .575/.595 so it is upto you but that is quite a bit over the recommended max lift for me to feel comfortable
Patriot Performance dual springs are available for the LT1.... good to .650 lift. Might need -.050 keys if you use SA rocker arms and have .250 tip valves.
Advantage: COST! The 918s are spendy; the PP are 250 or so and include seats, titanium retainers, keys, and all.
Be SURE to consider installed height and seat/open pressures whatever spring you go with.
