water pump
Old 03-03-2007, 07:33 PM
grnmonster's Avatar
Default water pump
i reecntley discovered that my water just started leaking is there any chance that it leaked on my opti and ruined that?
Old 03-03-2007, 07:43 PM
My25thTransAm's Avatar
Mine was leaking for the longest time and I haven't had any problem with my opti...yet. Water pumps in lt1s blow...
Old 03-03-2007, 07:45 PM
grnmonster's Avatar
indeed they do suck...but so do the opti
Old 03-03-2007, 08:26 PM
James Montigny's Avatar
You are probably ok, but it would be a good idea to fix that soon.
It's not overly difficult, just try not to spill all the coolant on the optispark.
Consider upgrading to an electric water pump while you are at it.
Old 03-04-2007, 12:03 AM
transambandit's Avatar
well if you are going to go through the trouble of pulling off your pump you might as well get a new opti, the opti doesnt fail because the water pump leaks, it fails because it corrodes due to being leaked on, so it might be fine right now but in a few months after it has corroded you will have to pull everything back off and reinstall a new opti.
Old 03-04-2007, 07:31 AM
Lt1CamaroSS's Avatar
im wp is leaking too..what has to come off to take off the wp?
Old 03-04-2007, 08:52 AM
Just the WP and those hoses that connect to it.
Old 03-04-2007, 02:30 PM
a lot more than that, you have to take off the crank pulley, and take off the air pump and let it hang, then there is a metal bracket behind the air pump that has to come off so you can get to the last bolt on the water pump, its not difficult it is just time consuming.
Old 03-04-2007, 09:39 PM
Uh ... no ...
Why on earth would you take the crank pulley and AIR pump off?
Step By Step: http://www.projecttransam.com/projects9.asp
Old 03-04-2007, 09:41 PM
can i do it w.o taking the radiator out?..im getting an electric pump too..how hard is it to take the replace it?
Old 03-04-2007, 09:43 PM
Radiator stays in, just have to remove one fan (4 bolts) and modify the shrowd.
(See Howto in previous post)
Old 03-04-2007, 10:02 PM
Uh ... no ...
well considering i just pulled out my water pump to do this exact same install i had to pull off the crank pulley and air pump to get to all of the bolts on the drivers side. Otherwise there was no way to get the water pump out without taking that stuff off. But hey your welcome to try and fail without taking the pulley and air pump off.
Old 03-05-2007, 07:14 AM
Done it many times.
The crank pulley only comes off when you need to get to the timing cover.
The rest of the bolts are easily accessible using a socket wrench and 3" extension.
Old 03-05-2007, 08:28 AM
chree's Avatar
Anyone tried an AIRTEX Part # AW5068? This new pump is ~$80 (RockAuto, Northern Auto Parts, etc).
