Was thinking about deleting AC?
Was wondering if anyone else has done it and how hard is it?
I want to clean up the engine bay and lose some weight.
I know I will need the 1LE ac delete bracket, where can I buy this?
After taking out the condenser do you have to change anything with the radiator and fan mounting.
One other thing how did you guys get rid of the refrigerant?
Thanks for any help.
Rick
Rick
Rick
Rick
Keep an eye on the for sale section, the 1LE AC delete comes up for sale every so often.
Radiator and fan mounting stay the same.
The refrigerant? I stuck a flat blade screwdriver in the valve and let it fly.
Keep your face out of the way though.
The Merve, ya I had seen a post from what you did with your AC and when I pull the motor I plan on doing the same thing. It looks really good, nice and clean.
So then it is pretty straight foward, let out the refrigerant, disconnect the lines, remove the condensor,and take out the compressor and add the 1 LE pulley and bracket. Does that sum it up or am I leaving something out?
Thanks again guys
Thanks again guys
Is this bracket any good from summit http://store.summitracing.com/egnsea...5&autoview=sku
Or should I try and find a 1le bracket?
The pic doesn't look the same, but the description is the same as the 1LE.
Pretty much. Just unplug and disconnect all the AC junk, and take it out. Then you might have to smash apart the box on the Fire Wall a little bit. Get it flush and get a panel on it, and you are good.
Thanks again guys
Thanks again guys
