LT1 belt tensioner
Old 03-05-2007, 09:12 AM
rmpitzer's Avatar
Default LT1 belt tensioner
I bought my 97 TA this past September, and replaced the squeaking belt tensioner with an Autozone tensioner. It lasted about 2 months and started squeaking. I pulled it out, brought it back with the receipt, and they handed me a new one. I put that in, and now that one is starting to squeak.
I assumed the Autozone tensioners are just crap, but before I go out and buy a factory replacement....I wondered what you folks recommended?
-Rich
Old 03-05-2007, 10:37 AM
Low N Slow's Avatar
Did you try a new belt? I have fixed a few squeakers by replacing it.
Old 03-05-2007, 11:01 AM
rmpitzer's Avatar
The belt alone did nothing, it was the tensioner doing the squeaking. Kinda makes me wonder...if something is making it squeak before it should...or if the Autozone tensioners are just crap.
Old 03-05-2007, 11:27 AM
hyperzone's Avatar
So, the tensioner piece itself is squeaking? I'm an advocate of checking junkyards... maybe grab a stock one there.
Check that all your pulleys/balancers/wheels are inline and none of them are protruding out or in a little. On my 3rd gen I had years ago, I had a pulley put on backwards which was causing me to eat through a new belt about every 2 months. It sounds stupid but it wasn't obvoius from first glance, and after 3 or 4 belts I sat and looked at it for a while, compared to a buddies and identified the problem. Maybe something similar here...
Old 03-05-2007, 01:01 PM
In-Zane Moderator
ZONES89RS's Avatar
I am just wondering, how much was the tentioner? I bought a 95 that is not assembled and it is missing this component.
Old 03-05-2007, 03:03 PM
rmpitzer's Avatar
It was shockingly cheap from Autozone, around $26 IIRC. Which is making me wonder if they are just junk.
I see nothing blatantly obvious wrong with any other pulleys, everything seems straight and true, and the belt is not wearing unevenly or anything.....it's just these tensioners only last a couple months before they start squeaking.
-Rich
Old 03-05-2007, 03:07 PM
sleeperMULLET's Avatar
just get a AC Delco one from gmpartsdirect.com its part #12552509 and its $32.16
Old 03-05-2007, 03:13 PM
rmpitzer's Avatar
Awesome, thanks for the part number!!
Old 03-05-2007, 03:21 PM
no problem, I stopped buying cheap stuff like that becasue it usually doesn't work and I end up replacing it with AC stuff anyway.
Quick Reply: LT1 belt tensioner
