removing the front struts
Yup, 2 on the a-arm, 4 on strut tower(under the hood), might have to use a pry bar to lower the a-arm enough to get it out. The upper control arm mount comes out with the strut so I'm not sure if you have to bust a ball join loose, but it's probably not a bad idea.
Originally Posted by ckyconan2003
yea...it's aint easy....i got all the bolts loose. I think ima removed the spindle
