BMR K-member??
BMR K-member??
OK I have the front of my car all apart. Replacing upper and lower ball joints tierod ends shocks and springs.And also deleted the A/C. So now I was thinking about getting a BMR K-member since I have every thing apart. But before I buy it I thought I would check in here with the experts to find out what experence you guys have had with them. So any info will be greatly apreciated.
Is there a better K-member that I should be looking at??
Thanks again guys
Rick
Thanks again guys
Rick
Thanks for the input guys. I have pacesetter long tubes does any one have these with the BMR or UMI k-member?If so were there any issues with the way they went together?
Thanks guys
Rick
Thanks guys
Rick
Ryan
go with UMI i have several of their parts on my car and all of them fit great and work perfectly and like they're susspoed to and if i had 450 bucks laying around i would get a K-Member cause my motor is out and i REALLLLLLY want one but definately go with UMI. It's better quality.
I'm running the BMR K, upper/lower A's & TrakPak, the K works fine, clears the Kooks & Canton pan w/o issue. Spent some time researching prior purchase and the quality between BMR & UMI are both topnotch.
Would these tubular K members hold up to Auto-x, Road Racing, or some good ole mountain passes...I'm all about the turns, and you can feel the weight in the front pushing big time. I already have the rest of my suspension sorted out.
Sorry for the Thread jack
It all right there nighthawk I was actually wondering the same thing because I kinda want to get into some autox.
So Ryan from UMI how is your k-member for auto x. If you are still watching this thread if not I will send you an e-mail.
Thanks
Rick
Thanks
Rick
