Question on cams
Question on cams
I am pretty sure but wanting to verify, can you not use a cam for any 87+ SBC in a LT1?? So long as it Requires thrust button and wear plate?? Just wanting to verify this. Thanks for any help. it is a 95 model motor with center dowel for opti.
You won't need the center drilled out if you have a 95, but not sure about everything else. I guess the gear is still on the rear of the cam and make sure the dowel pin is the right length for the opti.
