CC306 cam and CC986 springs
Old 03-10-2007, 07:48 PM
jakesz28's Avatar
Default CC306 cam and CC986 springs
I just got a CC306 cam and CC986 springs with the 747 retainers but now I wonder if I should get a different spring. That is what was recommended but I didn't realize that spring is only good for .560 lift. I wanted to run 1.6RR. So will that spring be ok with 1.5RR or is it taking a chance on valve float?
.510int .540ex
Old 03-10-2007, 09:41 PM
azvforce's Avatar
I am running the CC306 with 1.6 rockers and 986 springs. I have ran this combo for years with no problems. I make peak HP at 6200rpm with unported factory heads.
Old 03-11-2007, 07:50 AM
jakesz28's Avatar
Do you have the beehive 986 or the double valve spring (Jegs 249-986-16)? I would hate to put this together and have a problem.
Old 03-11-2007, 09:18 AM
one eyed willy's Avatar
my cc306 card said to use 918's
Old 03-11-2007, 03:37 PM
Matts94Z28's Avatar
Im using the 918's...They say they are good up to .600
Old 03-12-2007, 02:23 PM
azvforce's Avatar
I have the double springs.
Old 03-13-2007, 08:49 PM
jakesz28's Avatar
Thanks for the info.
Some people say yes others say 918's.
I already have the 986,s retainers, locks, locaters.
The 987 would be a cheap upgrade but then spring pressure is higher.
Old 03-14-2007, 10:45 AM
jclt12003's Avatar
i'm running the 918's with a GM847 have not installed the set up yet in the process of doing that now.
Jason
Old 03-14-2007, 11:25 AM
wkniffin98ss's Avatar
I would go with the 918's. The 987's are overkill and they are a lot wider than the stock spring. The 918's are a direct replacement for the stock springs.
Old 03-14-2007, 11:27 AM
Do it right the first time, get the stuff you know will work, dont guess on anything.
Quick Reply: CC306 cam and CC986 springs
