Rod and main bearing help!
i was looking at the Clevite 77 H series. my setup is a 355 with a blower. forged 5.7 scat I beams incase anyone needs to know for the rod bearing.
now what is the difference from the standard to H series bearing?
my plans are 10psi intercooled.
what size rod and main bearing do i need and what version should i get?
thanks
thanks
well i found out that since i'm using the stock crank,that i should use the Clevite P series and not the H. anyone have any part numbers for the P-series that would work with my rods and main.
