trick flow
trick flow
I am going to build a 383 stroker what do you guys think the trick flow heads 195 from summit would be a good idea to run with it and the comp cam 306.It will be a dd.
Originally Posted by BlackScreaminMachine
Your going to need flat top pistons and probably still have to mill the heads, as of last year these heads dropped compression on the motor and compression is what makes power.
I have no need for it, im out of the LT1 game, this advice came straight from the mouth of both Lloyd and Bret when I was still working on my 383 LT1 just a FYI
Originally Posted by 96SOM383
Man if you really want to set that 383 off trick flow is coming out with the new 240cc heads......
Airflow Chart for Super 23 Race CNC Cylinder Heads
Lift Value Intake Flow CFM Exhaust Flow CFM
0.100" 69 55
0.200" 144 112
0.300" 213 158
0.400" 265 195
0.500" 296 220
0.600" 305 234
0.700" 310 240
Tests conducted at 28" of water (pressure); exhaust with 17⁄8" pipe.
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
LS1TECH Sponsor
For those that are interested that is a 230cc head. Here are the numbers on that head.
0.100" 69 55
0.200" 144 112
0.300" 213 158
0.400" 265 195
0.500" 296 220
0.600" 305 234
0.700" 310 240
0.100" 69 55
0.200" 144 112
0.300" 213 158
0.400" 265 195
0.500" 296 220
0.600" 305 234
0.700" 310 240
Any exotic valve train required for this head?
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
No special valvetrain required.
__________________
We do not sell direct. Check pricing with one of my dealers. Here is a link to the list.
http://www.trickflow.com/dealers/dealers.asp
__________________
The combustion chamber is 70cc.
__________________
the trick flows are nice, but if your goals are 11's and on a budget, ported stockers will do the job and save some $ for other mods!!. Now if your tryin to run low 10's or 9's na then the trick flows would be a good investment. DO some searching and you will see that ported stck heads will flow like aftermarket castings, unless you have the aftermarket pieces ported. Again it depends on your budget and goals. Throwing parts on a car does not make it fast!
