View Poll Results: Should i do the header install myself?
Yes
100
90.09%
No
11
9.91%
Voters: 111. You may not vote on this poll
Header poll
It is extremely straight forward, just takes a lot of patience. If you have some confidence with tools you'll be fine.
My biggest advice is to soak the factory exhaust manifold bolts in PB blaster the day before. That will make your life a whole lot easier when you plan on pulling them off. I am sure other people will post in their $.02 with tricks they've found to work as well.
Here is a writeup done by Javier -- it should help you some as well
http://www.zmydust.com/headers/index.htm
PB Blaster you can find at any hardware or local autoparts store. It is the same as liquid wrench, WD40, etc. They just help loosen the rusted, 12+ year old, heat cycled bolts that hold the factory manifolds on. Basically you just have to let the car sit for about 12 hours befor you plan on doing the install, and just spray the bolts down every hour or so and let it soak.
Basically take a look at that link I put there and see if it seems like something you'd be interested in doing. If not, shop around and see if you can find a shop to do it for a reasonable price.
yes, pb blaster, 3/8ths (i believe) craftsman ratchet wrench. because theres not much room to turn back forth. you will wear out your forearm turning a regular wrench over and over and over and over. trust me. i put headers on my lt1 and my brothers ls1. both were a bitch but we got em done. it was all better when your drinking beer and staring at them when your done. you sleep real good too. good luck!
Go ahead and do it. It's headers now but on down the road you'll want more done to your car and you'll love not having to pay for it. Also get experience, you will be suprised at how many people will pay you good money for installing mods on their car. That's what I do when I need spare money.
The reward of hearing your exhaust fire up for the first time after you've been laying on your back for a weekend is enough motivation to do it your self. Why let some mechanic have that privlage.
As far as extensions go I just bought them from thunder racing, that way I don't have to worry about crimps failling. I also had to buy new O^2 since the old ones refused to come out.
My most important advice, in addition to the above mentioned, is over budget and don't get frustrated, even when your on your back at 3am and the exhaust doesnt want to line up.
Originally Posted by 95camaroz28
Do you need to take the passenger side valve cover off to get the header ?
That damn egr tube in the back of it realllllllllllllly made it much more diffuclt to get in. Had that not been there they would have slid easialy into place from the bottom. If you dont need the emissions stuff dont get it. Little easier to install.
I took my stering shaft out for the drivers side an went in easily.
You don't need a poll to determine if you should install or have them installed? Dude get a fellow fbody enthusiast to help you and get this done, time you finish reading this poll you'd be finished and you'd save the labor. Several writeup how-tos all over the place, with pics too.
Definately use pb blaster or kroil oil. WD-40 is a lubricant and also used to dry moisture out, it is not a rust penetrator. Just let them soak and you'll probably get them out. If that doesn't work you can alway use every mechanics best friend the torch.
