Anybody using the 26120 Beehive w/ hydraulic rollers?
Old 03-21-2007, 08:57 AM
cdb95z28's Avatar
Default Anybody using the 26120 Beehive w/ hydraulic rollers?
As title says..........
using these vs. the 26918 beehives, more load, any long term effects on the HR lifters?
Thanks!
BTW, I`m going to use the new GM Racing CTS-V Caddy lifter.
Old 03-22-2007, 09:53 PM
seawolf06's Avatar
I heard those were more for a BBC. They also seem to have less lift capability. Why do you need more pressure?
Old 03-22-2007, 10:04 PM
cdb95z28's Avatar
They are .590" max lift, 918s to .600"
I was told that these can be used for more agressive lobes.
Old 03-23-2007, 02:43 PM
seawolf06's Avatar
I tried looking at those, but my max lift was .585 which was too much and I think the rate might be less for those, which makes me think that the spring is just shorter.
Old 03-25-2007, 07:20 PM
CNB
CNB's Avatar
I use this spring on my set-up which is currently at .637 lift. This spring is very stout and tests out stronger then what Comp advertises. Here's a picture of the springs with my new motor.
Quick Reply: Anybody using the 26120 Beehive w/ hydraulic rollers?
