is this a good price for a reman LT1??
I got a quote of $1972.00 INSTALLED from a ASE Certified company for a remanufactured engine that includes
New valves
New valves guides
New valve Springs
New Pistons
New Piston Rings
New Oil Pump
New Long Block Gasket Set
New Lifters
New Timing Chain & gear set
New Spark Plugs
New Spark Plug Wire Set
New Air & Oil Filter
New Thermostat
New Oil and antifreeze
A 3 year /50,000 mile warranty
For my 94 Camaro Z28… do you think that’s a deal or what!!!
THE REMANUFACTURING PROCESS
Quality Control
AEI puts quality at the top of our list because your product has to last. An intensive process control system is used to monitor all aspects of the remanufacturing process. Components are inspected after each operation and procedure. Only the highest quality parts and machine work are provided.
Engineering
At the Fliteline engine remanufacturing plant, extensive research goes into casting numbers, machining processes and tolerances, new part vendor selections and product applications. In addition, operators go through training that focuses on unique product features and processes. Potential problem areas may then be identified and corrected.
Disassembly
Each core is disassembled and inspected. Those components not suitable for further processing are scrapped. All small parts are cleaned and critical tolerances are checked. Worn parts are scrapped and replaced. All major components (crankcases, cylinder heads) are baked in gas-fired ovens to carbonize grease and dirt. Other components are chemically cleaned.
Components then go through an abrasive blaster that removes all contaminants. Crankcases and cylinder heads are all magnafluxed to check for any cracks not found during visual inspections. Each component then moves to its respective matching area.
Crankcases
All freeze plugs are replaced and the water cavities are pressure checked for integrity.
All holes are tapped and drilled, passages are cleaned and repaired if necessary.
All cylinder bores are measured and taken to the same oversize dimensions.
Diamond cutting hones are used for final bore sizing to ensure that surface finish requirements are met.
Main bearing boxes are line honed to ensure uniform size and alignment.
New cam bearings are installed and checked for free cam spin.
Crankcases go though a final wash to remove any remaining contaminants from the machining process.
Crankshafts
All crankshafts are checked for straightness before any further processing occurs.
Excessively worn journals are welded, reground and polished to process standards.
Reground journals are blended with the fillet radii to remove any stress risers that could result in crankshaft breakage.
All oil holes are chamfered at the journal surface to remove all sharp edges that could impede oil flow or damage bearing surfaces.
Connecting Rods
Each connecting rod is checked for cracks, damage and straightness.
All crankshaft bores (big end) are resized to new specifications
Where applicable, piston pin bore bushings(small end)are replaced.
Center-to-center length is then measured to ensure process compliance.
Camshafts
After cleaning all cams are inspected for straightness and lobe conformity.
If grinding is required, the cam contour and timing is maintained to original specifications.
All lobes are polished to ensure uniform surfaces and smooth performance.
If non-remanufacturable, new is used.
Cylinder Heads
All cap plugs are replaced.
All cylinder heads are pressure tested to verify water jacket integrity.
All decks are inspected and machined as required to reach required specifications.
Valve guides are resized or replaced as required.
Valve scats remachined with 3 angle cutters for proper flow.
All older heads with non hardened exhaust seats are replaced with hardened scats to allow operation with unleaded gasoline.
After assembly, each valve is vacuum checked to ensure proper seating and sealing.
Final Engine Assembly & Testing
All engines are hand-assembled by senior experienced technicians. Engines are live tested for correct oil pressure, vacuum pressure and compression to ensure that your newly remanufactured engine will provide years of service.
Our Commitment to You
To offer you the best service possible, we are continually refining our process to provide you with the most up-to-date information possible. We appreciate your business and would like you to feel free to contact us with your thoughts.
We know that in today's market, having the best product is not enough. That's why at American Engine Installation we will do what it takes to satisfy you, our customer.
New valves
New valves guides
New valve Springs
New Pistons
New Piston Rings
New Oil Pump
New Lifters
New Spark Plugs
New Thermostat
Quality Control
Engineering
Disassembly
Crankcases
Crankshafts
Connecting Rods
Camshafts
Cylinder Heads
I would get it balanced. And torque plate honed. But price looks great to me. Especially installed. You sure they are aware this is an LT1 motor ? Kind of strange they are offering new lifters and same cam...if anyhing that is typically the other way around in a roller camshaft applicatoin. I paid $2800 about 2 weeks ago for my complete rebuild on mine...NOT installed. Mine was total junk though - head castings were the only part re-used. The block was even garbage on mine. I bought the car that way by the way...Anyhow - your price looks good to me.
Originally Posted by DroppedM6Z
I built my forged 355 bottom end for 1K and installed it for free.
