P0336 Crank Position Sensor Performance AND misfire problems
Old 05-07-2007, 05:59 PM
emerica4601's Avatar
Location: king of prussia, pa (home) and williamsport, pa (school)
Default P0336 Crank Position Sensor Performance AND misfire problems
Need some help here. just replaced the opti (again) ... and it still doesnt run right. we put in a used 50k mile stock opti and it runs like sh*t. im throwing the code of p0336, and im assuming htat has to do with the startup. its is REAL rough starting up. alsmost like it has a dead battery.
i just bought a new crank position sensor, and am hoping thats the problem. I know that they are different than the lsx engines, wehre you might have to relearn the pcm with the new sensor.
any suggestions on the sensor, and on why car runs like complete sh*t???
Old 05-07-2007, 07:50 PM
to the top
Old 05-07-2007, 10:02 PM
Captainofiron's Avatar
just make sure you unplug the battery of the car overnight. thats what I always do when I replace sensors.
Old 05-08-2007, 02:51 PM
to the top
Quick Reply: P0336 Crank Position Sensor Performance AND misfire problems
