do manifold bolts commonly break?
Old 05-09-2007, 08:54 PM
littlebird's Avatar
Default do manifold bolts commonly break?
I am contemplating my next mod to be cat back or headers (in any order) and I was warned by a guy who said I would probably break off a manifold bolt due to the fact that it is a 1994 model. is this likely to happen and how much of a pain in the A would it end up being. i know everything on my car is a pain to fix\change.
Old 05-09-2007, 09:07 PM
Revelation Z28's Avatar
i took mine off with no probelm, but the drivers side very front and very rear ones were broken. headers dont use them so they are stuck broken.
Old 05-09-2007, 09:12 PM
Ralls's Avatar
It's possible, but not guaranteed to break. If your worried about it, heat the bolt up with a oxy acetylene torch and it will come right out. My y-pipe studs broke off but I didn't care cause I wasn't ever going to put them back.
Old 05-09-2007, 09:35 PM
94Pontiac's Avatar
a couple of mine were missing and the rest were finger tight lol
Old 05-09-2007, 09:37 PM
matt94z's Avatar
It is pretty common. I had one that broke.
Old 05-09-2007, 10:21 PM
Ls1Bait's Avatar
Spray them down with PB blaster or other sort of penatrating lube and let them sit for a couple hours (longer if possible) you should be fine
Old 05-09-2007, 10:55 PM
matt94z's Avatar
I sprayed mine with PB Blaster the night before and then before I took the bolts out. It does help, but doesn't solve bolt fatique problems.
Old 05-09-2007, 11:00 PM
the_merv's Avatar
I haven't had a problem...the Header Bolts that come with the Pace Setters like to round off, I had to grind off the Heads and get them out that way.
Old 05-09-2007, 11:44 PM
anyone try allen bolts?
Old 05-09-2007, 11:56 PM
Captainofiron's Avatar
my Y-pipe bolts broke, but its really humid here and the gulf is real close, so I can imagine they rusted pretty badly and thats why they broke
Old 05-09-2007, 11:58 PM
i impacted my fruit loop of a stock Y pipe off. bolts were rusted more than a nova's chassis. they came off cleanly.
ps i used 15-20 yr old penetrating oil
Old 05-10-2007, 06:36 PM
InsaneAuto86's Avatar
[QUOTE=matt94z]I sprayed mine with PB Blaster the night before and then before I took the bolts out. [QUOTE]
I did the same thing. No problems at all!
Old 05-10-2007, 07:43 PM
emerica4601's Avatar
Location: king of prussia, pa (home) and williamsport, pa (school)
i soaked mine in PB for 2 days
came off no problem
Old 05-10-2007, 07:44 PM
Hot94Z28's Avatar
I had one break. Thats why I put headers on
