Lingenfelter cam?
Lingenfelter cam?
any one ever run an lpe cam? i found this one 219/219 duration, .560/.560 lift with 1.6 rocker 1200-6200 rpm range. wonder if it be any good? know id need 1.6 rr's new springs and etc.
I ran the 211/219 for a few years with stage II heads, made 327HP and the car passed smog cleaner then stock. It is a great street cam with plenty of torque around 2,200 to 5,000. It wasn't great for ET as it fell off badly by 5,500.
thanks guys, im probably going with the 219 now, i keep changing my mind, but ive only heard good things about lpe and figured id ask around and see what yall thought
I have to say that i loved this cam.. for alot of street use, i ran 11.9's at the racetrack with 10 bolt and 3kstall. with a little spray i would have been in the high 10's. This was in a 383 factory ported heads.. equivilent to LE2 o guess. Of course im in a G-body weighed like 3400 with me in it. 1.59 60 111mph trap (little low). You will want to change to 1.6 rockers and new springs, i would even change out lifters if they are stock but thats just me.
Freind just put his 219 cam up for sale as he's going with a different combination. If you interested, his handle is HardcoreZ28 on WWW.NJFBOA.ORG
I ran the LPE 211/219 .533/.560 for years in my 383 trapping 115 with high 11's/low 12's....The 219/219 is a terrific street/strip cam with great lift numbers with shorter duration...LT1s love that combo...That was the cam I was going with before I got the Joe O. cam...Call LPE and get the spring package they recommend...If you don't buy the cam used from the forum, get the whole cam/spring package from LPE....
--Alan
--Alan
