How much am i gonna spend...
ok i might go all out and build my camaro up
here is the price list let me know what u guys think im gonna spend in the end. as well as where the best place to buy the parts.
these parts i can install myslef with some friends.
Pacesetter LT headders- $550.00 no install
4:10 gears- $265.00 no install (also need a install kit)
what will it cost to install these parts?
cam- approx $250.00???
heads- approx $500.00???
tune- ???
tune- ???
thats not all out
pacesetter lt's are not 550 more around 365
cam around 285
$500 might get you a minor port job using your heads and tuning
is around 250 from pcm4less
heads and cam install will probably run you around 1000
cam around 285
Well Id say its not gonna be cheap at all to have the heads and cam installed will probably run more then you payed for the work done to the heads. I would really do a read up H/C installs are not hat hard if you know your way around a car.
well i have a buddy who's dad is a mechanic...so my buddy can disassemble and partly install the gears but his dad will have to spend about 2 hours or so finishing up.
As for heads ive heard that its about the same price to fix them up as it is to just buy new ones...?
that is only a minor chunk of the change there is so much stuff you will end up replacing..i can promise you making a list aint the way to go cause it always gets overlooked when other stuff you never would think about comes up...i planned on spending 2000 on my engine rebuild and have over 4100 in it now
