timing chain help
timing chain help
Last part i need for my cam swap is a timing chain. I was talkin to bret and he suggested the ProGear set@$80ish and that it was real easy to deg. the cam vs. the Cloyts one. And i also seen a Lunati one for $188 that was a full roller. What one are you guys using and do i need a lt1 specific one or any hyro-rolelr cam years 87+? I would assum not because of the opti pin correct. So whats a good one?
Cloyes dbl roller here... I had to pull my timing cover shortly after getting it running for something or another. And it was making slight contact with the cover, but nothing 5 minutes worth of grinding couldnt solve.
FWIW, the hex-adjust cloyes setup will not work if your going to be running an opti. The adjustment mechanism doesnt allow for the opti to mate with the cam face.
Originally Posted by 95greenZ
If you have an ewp and swapped to vented opti you could run a sbc timing set. I'm running the cloyes double roller.
Originally Posted by 96capricemgr
Timing cover, timing set, opti, wiring from opti to the connector up along the intake manifold.
i emailed bret and he said that i need a LT1 specific timing chain so im assuming that the progear wont work on my '94 cause i dont have a vented opti. So im gonna go this route........
http://store.summitracing.com/partde...4&autoview=sku
