HELP! I need some pictures...
I need close up pictures of the intake manifold (on the car) and all the connections that go around it. Real good close ups if you can. I think I mixed up a few connections and I can't find where the bracket for the throttle linkage connects to.
Well here are some things I need help with:
This is the throttle cable brace I was referring too, where does it go and how does it go on where it goes? I have an idea that its suppossed to go on the manifold, but which way?
After talking off the throttle body and playing with the throttle cable while i was removing and reinstalling the intake, i wasnt sure if i goofed up any settings, does this look right? (i guess this would be idle?)
and where the hell does this little guy go?
TB blades should be closed completely. I think that bracket is for the EGR solenoid... and the vacuum elbow could be for the fuel pressure regulator. Here's some more pics. BTW, I don't have any kind of brace for my throttle cable.
edit: the flash makes my engine look filthy. Blah.
Throttle blades should be fully closed, the iac valve controls the idle. You must have the cable in a bind or something take another pic showing the whole throttlebody if you havent' figured it out yet.
UPDATE:
I found the throttle cable holder, I think it went on the same bolt as the EGR (back of the intake manifold, drivers side). I fixed my throttle cable so the blades closed.
Fired it up, everything runs great.
I just have one last question:
What's this? Does it have something that connects to it?
^^^isn't that the evap purge solenoid? I mean the piece with that little rubber vacuum elbo... If so, it just vents the fumes from the charcoal canister into the intake....
