track results, its gettin better, but not quite there
I finally got out to the 1/8 track last night, here are the results:
r/t .154
60' 1.64
330' 4.619
1/8 7.09
mph 98.86
My setup consists of NX DP kit ,Ported AFR heads 217 cc, ported lt4 intake,37lb injectors, 58mm t.b. , 240/246 cam, th400,art carr 3600 on t-brake na, hals shocks, skinnies, m/t 28 x 10, 3.73 gears. My raceweight with me is 3400
Last year when I had my vig 4000, I cut a consistent 1.47 - 1.50 60'. I played around with the shocks and tire pressure. I was running 10 lbs in slicks cold. This was on 150 shot, so If I can get my 60' down to where it was last year, ill be running faster on the 150 than the 250. How much pressure are you guys running in your tires that have t-brakes and nitrous. Do you guys think I could have a 10.50-10.60 car on the 150 shot? What else can I do to get my 60' times down? Thanks in advance, Chris
r/t .154
60' 1.64
330' 4.619
1/8 7.09
mph 98.86
Originally Posted by Juicedz
I tried 12,11,10. 10 hooked the best, i'm, pullin the wheels 4 or 5 inches and carrying it out for about 30 ft, but my 60' time is only 1.64
damn mine stay on the pavement on 1.50 60'
id say theres something up, i ran very similar times with 306 cam only stock heads and 125 shot on a window from 4k-6400
1.50 60' and 7.0 at 100 all day, stock suspension 4.60-e with a 3200 stall stock wheels with mt dr
If you go lower then 10lbs, i would run rim screws tho.
