Weird Starter Issue
Weird Starter Issue
Hey all-
I woke up this morning to leave my girlfriend's house (a painful experience, as usual), and found that my Trans am wouldnt start =/ it wouldn't turn over. all the accessories worked, everything. i even tried jumping it, just to say i tried. no luck
so i come back later, and think its the starter. i tear off the starter, and go get it tested. it checks out good. i put it back on the car.... install it back in place. as soon as i put the negative battery cable back on, the starter began spinning uncontrollably until i took the cable back off. i thought this was odd, so i decided id just take the starter off and play with it. anytime i grounded the starter case to the frame the motor would spin, and there would be a spark....
i tried a new starter-- same issue.
anyone have ANY ideas? i'm so lost... so confused.. blah.
Thanks!
Thanks!
Well I once had my starter off and I accidentally had the two terminals touching and that caused the starter to engage once I hooked the battery up. But you said it did it on a different one too so I don't now.
Hey i had thae same problem with mine.. I Have Hookers lts, Aparently the singal wire to the starter started to melt down and show bare wire and it would occasionaly ground it self to the header and make a circuit. It took me a few days to figure it out. I just took the wire comning off the main harness andreplaced it and re routed it and everthing works fine now.. Hope that helps ya
