Cleaning Air Filters
Go to the parts store and a lot of times they will have the cleaner and oil on the shelf (or at least mine do). I don't think the cleaner is all that a big a deal cuz you can spray them out pretty well with high pressure water. However better get the oil so they'll trap dirt like they're supposed to. I got lucky one day and found the oil in an aerosol can so it went on really easily.
The K&N kit comes with the degreaser and oil but all you really need is the oil since you can clean with pretty much any degreaser. I just don't know if you can buy the oil separately.
All you do is take off the filter spray it with degreaser than spray it with the water hose, from the inside out so your not imbedding more trash in the filter. Wash it a couple times or till it looks clean then let it dry. Once its dry spray a new layer of oil on it. And the oil will be pink at 1st so you know not to go over the same spot alot and put too much. Make sure you just make the filter pink and thats it because if you pack it on then you will have to clean your MAF from the oil getting it dirty.
All you do is take off the filter spray it with degreaser than spray it with the water hose, from the inside out so your not imbedding more trash in the filter. Wash it a couple times or till it looks clean then let it dry. Once its dry spray a new layer of oil on it. And the oil will be pink at 1st so you know not to go over the same spot alot and put too much. Make sur you just make the filter poink and thats it because if you pack it on then you will have to clean your MAF from the oil getting it dirty.
