PLease help just started new 383 Motor!
Please Help i just started my new engine last night and there are a few things wrong.... It seems like it is not firing on all cyliners... I have a brand newopti spark on it new Wires, new plugs, new blaster coil and everthing.. When we first fired it up it was camming/idiling good. Then it started to develop a bad miss and we test drove it. What could it be? Also the guy i go tthe car from before deleted the heater coil and the air bleeding valve as well so i think i have some air pockets in the head as far as that goes. We got a ton of air out like 4 or 5 times, Then the temp if fine for lil bit, then the gauge starts bouncing around like a tach.. someone please help with some input i am dying to have this thing running!!
Yes i got a tune from brian at pcmforless and yeah i opened the radiatior carp and fill the overflow. Yeah i am looking into the burn plug sit. but they were brand new.. Yall have any idea on routing them a diff way? like on top the valve covers then down, Didn;t know if there is a kit out there for that?
the temp gauge bouncing sounds like you still have air in the system. check to make sure all the wires are making good contact too. i cranked my car after doing h/c and it was fine for a bit then starting dying and smoking. the wire was barely on and actually blew off the plug. did it start running shitty when it was at operating temp?
