Do I need a stall w/cc503
You can, but I would definitely NOT recommend it. I have the 230/236 Comp cam and it is a pain to drive with all the cam surge. I'm used to it now, but it will get on my nerves more times than often. Get a converter if you can.
Moderator
I run a Vigi 3200 in my TA, cant see why you would not want a stall. Doesn't hurt drive ability at all and the performance gains are better than any thing else you can do, maybe other than nitrous. Nothing gets you .5 off your times like a good converter would. Do the stall before the cam your 1/4 mile times will thank you. I bet you pick up more from a converter swap than you would a cam swap.
Originally Posted by StealthFormula
how do you think the cc503 cam with stock stall and 3.73's would drive?
Probably just fine.
I had 3.42's in mine with a stock stall without any problems, keep in mind I also had a stroker motor (385 cubes) which helped in low end power and driveability.
Originally Posted by the_merv
How does the driving change with a Stall.. I am putting in a Yank SS3600, and hope to get about 500 at the Wheels..
If you have a lock up converter you'll be fine.
It's a lockup, is there a way to get that to lock up lower..can that be set into the Computer at a certian TPS%..
It's suppose to lock up at 43 mph. You can change that with tuning. I know that because my converter locked up at precisely twice that speed at 86 mph. I sent the computer back to MTI (mail order tune) and they fixed it.
