94Z Project
94Z Project
Added Pictures of the install. Finally got it running after a few set backs. I don't have a video right now but its just open headers, but there is one in the works. Don't worry about the hose off the MAF it's just temporary
Well its been about a year since I've had this car and its finally coming together. All the hard work I've done is finally paying off. I bought it as a roller last July. It had nothing in it except a rearend with busted gears and its shell. Friend I've mine gave me a wrecked 93 Z with a good motor. Found other parts here and there. Worked on it when I had time, now I'm getting in the short rows. My goal is to have it running by the end of June. Still waiting on clutch so I can finally put the motor in. Waiting on somemore funds to . But heres a few picture and some specs.
1994 Z28 M6 383 Lt1
Eagle 3.750" Stroke 4340 Crankshaft
Eagle 6.000" I-Beam Rods
Mahle Forged Flat-Top pistons
Comp Cams "Extreme" cam 236 / 242, .520 / .540 112 LSA
Comp Pro-Magnum NSA Roller Rockers, 7/16" stud, 1.6 R
Comp lifters,pushrod,studs exc.
Ford Racing 30 lbs. Injecters
Ported Stock Lt1 Heads
Ported Stock Lt1 Intake
Cloyes double roller timing chain
Electric Water Pump
BBk 58mm Throttle Body
Pacesetters Long tube headers
ACDelco Dist.
EGR and A.I.R delete
All UMI Suspension
4.10 gears
All UMI Suspension
1994 Z28 M6 383 Lt1
Electric Water Pump
ACDelco Dist.
All UMI Suspension
4.10 gears
All UMI Suspension
Originally Posted by White 96LT1
looks like mine (where did you get those valve covers?) want to get some
Picked them up on Ebay, about $80 to $100 bucks. Had to cut them out alot to fit over the rocker arms thou.
Looks good! Just a word of advise (from exp) I had my acc bracket powdercoated and long story short the alt was insulated from grounding and caused electrical issues. Just a heads up if you have any probs just clean the bosses where everything comes in contact and it will be fine.
thought i recognized my old car in that sig pic...looks like you have dumped a ton of money in the car...this car has been through a slew of modifications once with me and now again!! unbelievable...if youve got any more pics, send them too me...always nice to keep up with a previous car...
Also I found that Sig. Pic. off Horsepowerjunkies...lol thought I put it to good use
You Still Got Your FLEET of Camaros?
Originally Posted by 94CamaroLT1
i have those same valve covers you wouldnt want to take one off to show me how you cut them to fit over the RR
my buddy has some chrome 10 spoke ss wheels with new rubbers up front and near new drs in the rear...they are in the for sale section if your intrested...as far as the fleet, its getting smaller...just sold a black one a while back to fergymoto as he posted but still have three and trying to get it down to one!! i really want to see this thing in person when its done...you have spent so much time and money and looks amazing so far!! and to think i had a lot of money invested...good luck on the completion!!
