Oil Pan and roll bar Question
Is an LT1 oil pan the same as a GEN1 except for the low oil sensor? Also does my 93 even have the low oil sensor? I was told they didnt start that until 1994. I would like to get a larger capacity pan but dont want to spend 250 on a canton. Thanks
Also where is a good place to buy a roll bar? what company? obviously weld in is better, but what could I run on a bolt in and not get thrown off the track?
If the pan was made for a one piece rear seal it will fit the motor. I run the late model Vortec truck pans on my Stock Eliminator LT1's. They hold one more quart of oil. I don't run them for the extra capacity, but the reduced windage that they create. If you are buying an aftermarket pan there is no guarantie that it will clear your K-member, but I would think that anything that will fit 1980's Camaro would work?
Daren
Daren
