EWP Roll Call!
EWP Roll Call!
I will be having an Meziere H.D pump installed on the Formula. I have a pretty good idead on how I want it wired. I removed the A.I.R. system last year. I already have the wiring issue covered. Accept for 1 thing. The A.I.R. doesn't stay on constant. Where do I tap to get my constant source? Could I simply used a fuse-tap off a constant fuse?
If you have an EWP. pics, suggestions, anything will help out, thanks. Show your install.
I don't have any pics but I ran my power wire to the fuse box on the drivers side shock tower (err in front of it)... There you will easily find a tab with constant switched power that you can put a spade connector in. Anyone that gives you 12 volts when your key is turned to the on positioin. Or splice into a wire underneath it with one of those blue connectors that splice one wire into another at any part of the wire....
