RPM's surge when cold start
Old 05-30-2007, 05:40 PM
litch2004's Avatar
Default RPM's surge when cold start
When starting car after it has been sitting for a while the rpms jump up to 1500 and the check engine light comes on. When i put it in gear it doesnt show me how fast i am going. After a little while the RPM's drop, the check engine light goes off, and it starts showing me how fast i am going. Also When you try and put the code key in and turn the key to the on position it will not flash any codes, it just stays steady. When you remove the code key and turn the key back to the on position it still responds like the code key is it. Any suggestions or comments?
I am also having a problem with my fuel pump kicking on. I have replaced the PCM, fuel pump, and the fuel pump relay but it will still not kick on when i turn on the car. Cannot figure it out at all. When i just the relay it works but it doesnt not kick off after the engine is fully primed.
93 Trans Am
98 Face lift
MSD Pro Billet Opti
New 8.8 wires and plugs
Pcm Replaced
New Fuel pump, filter, and relay
And all other New sensors- the IAC and the map sensor
Quick Reply: RPM's surge when cold start
