ud pulley help.....
ud pulley help.....
I am trying to install my ud pulley....
The crank keeps rotating with the wrench as I am trying to get the 3 bolts out.
Is there a way to stop that?
am I doing something wrong?
I used the one in the center to hold the crank hub while I loosened the other 3........
I am using the UD pulley partly because my PS fluid gets crazy hot, and I already had to swap the rack once..........
alright, I aquired an alternator pulley, and cant get the stock one off.
It looks like a nut in the center, with a bolt that uses a hex key. I cant keep the rest of the assembly from rotating when I try and remove them.......help?
