LT1 to a 383+ questions
Well my 93 T/A just hit 169k and im about to pull my engine to replace the front and rear main seal. I plan on sending my heads and intake in for a LE3 package. What is the amount of bore needed to be able to run this package?
Also i have built 383s on regular 350s but never messed with an LT1 before. Is it the same principle? 400 crank and all? And Ive been seeing people with 396 what all did you have to do to get that ci? any help will be appriciated.
and from what i have heard the LE3 heads will hit and it at least has to be bored to 355
A 383 LT1 is not a 400 crank. It's a 3.75" stroker crank combined with the .030 overbore for a 4.030" bore.... Once again rod choices abound with 5.85" usually being the norm but 6" rod 383's are not impossible... (I'm building one).... When you lengthen the rod you have to change the pistons structure so that the wristpin of the piston is taken up into the piston to compensate for the added length. If not your piston would come up and come out the bore at top dead center..... also block clearancing is required to clear rod bolts...
A 396 is a 3.875" crank with a 4.030 bore (once again a .030 overbore from stock).... more clearancing is required to clear rod bolts cause of the larger stroke. rod choices again are plentiful....
All of these motors see require a .030 bore... Don't go bigger than that you're first time because if you mess something up you can clean up the bore by going to a .040 or .050, .060..... so start with a .030 so later you can fix the bore in case something get jacked...... hope this helps...
I several LT1 383's going and have built many of them, just ask around about us. If you need heads, cam, machine work etc, I'm in Austin and would be happy to help.
Check out our website at www.PortPros.com
Harold
512-257-0222
Harold
512-257-0222
Originally Posted by litch2004
That helps out alot. Thanks OutlawZ
Good luck with your engine as well
Yeah Harold down at Portpros would be a great source of info for your build. Have a professional sit down with you and explain the pros and cons and prices of each on average... that way you make an informed decision based on your needs.... And harold did a beautiful job on my intake and built Tony Shepherds motor so he can do an LT1 from mild to wild...
LT1 's have big water jackets
LT1'S HAVE THIN Clndr. WALLS and cannot be bored to 4.10" so the math may be right but impossible with a stock block.http://images.ibsrv.net/ibsrv/res/sr....gif:confused:
There have been plenty of people running a LE3 kit on 350's, the thing is, they usually rebuild the motor with forged internals to handle the RPM needed to make power with that kit. When this is done they get the right pistons so your valves aren't kissing the top of your pistons. Also, usually when people do this they will bore it .030 over to get a smooth new mating surface for the new pistons. So when you hear of people doing a 355 to get a LE3 kit to work, it's not because the heads and intake won't work, it's so they can replace the pistons to keep the valves from hitting it.
Catch my drift?
