LT1 Water Pump Drive?
Old 06-13-2007, 07:57 AM
macsperformance's Avatar
Default LT1 Water Pump Drive?
Hello!
Guys I have had an electric water pump on my car for over 4 years now. I am replacing it with a new conventional water pump. I do not remember the direction the lip faces on the drive (pictured below). Is it toward the pump or toward the timing cover?
Thank you for your help in advance!
Chris Macellaro
Old 06-13-2007, 09:40 AM
dhdenney's Avatar
Oh **** I did this the other day and it never even dawned on me to look at that! I think I flipped it around a couple times til the water pump seated but I never paid attention to that! I guess we'll see if I have any leaks or anything down the road but it seems ok.
Old 06-13-2007, 10:16 AM
hashtagBMW
Speed Density's Avatar
The Ringed part goes towards the pump, I should know since I just destroyed mine last night
Tony.
Old 06-13-2007, 10:23 AM
dhdenney's Avatar
How did you destroy yours? I didn't use any o-rings on mine.
Old 06-13-2007, 10:29 AM
dhdenney's Avatar
I don't know why I am freaking out, seems like I have never seen o-rings on mine and I've had it off 4 or 5 times. Reading your all's posts makes me paranoid, lol.
Old 06-13-2007, 10:30 AM
hashtagBMW
A Hammer.
Nor did I.
If you were confused by the before post I was saying the Ringed/Lip part faces the water pump.
Tony.
Old 06-13-2007, 10:42 AM
fergymoto's Avatar
A hammer to seat your water pump?! LOL you should know better man!
Old 06-13-2007, 12:13 PM
Tony.
Tony, Thank You very much for your help sir!
And good luck with yours!
Chris Macellaro
Old 06-13-2007, 03:57 PM
dhdenney's Avatar
Tony.
No I wasn't confused. I just remembered seeing something about o-rings in the past and when you referred to it as "ringed," I started thinking maybe I should have used o-rings. But then I remembered I never used them before. Just get a little paranoid about the car cuz it seems like it's something all the time. This past weekend, I drove it a good distance and it was overheating and then I burned a wire on the starter and I had to have a buddy haul it in. You know how it is!
Old 11-21-2007, 03:36 PM
Bad93TA's Avatar
Exclamation Which way?
Shoebox has an exploded view of the water pump assembly and it shows the lip facing the motor. Im about to put my opti in on monday and need to know the correct way. Can someone give me an answer? Thanks
Old 11-21-2007, 04:05 PM
355z28's Avatar
yeah im kinda confused now because i think ive ran mine both ways ? why does it matter?
Old 11-21-2007, 04:19 PM
Bad93TA's Avatar
idk does it matter???? just dont want to install it wrong.
Quick Reply: LT1 Water Pump Drive?
