lt1 hei conversion
lt1 hei conversion
I have a 95' LT1 from a Impala ss, I've been doing some research on converting from the optispark to a conventional HEI style distributor. Any help and info would be greatly appreciated. I've heard that a 90-92 TPI distributor, harness, and computer can be used.
Sure can, a slight tune will help even more.
Here's what your intake will look like, with the exception of the coolant ports. Those are only required if running a LT1 intake on a Gen1 engine.
http://www.lt1intake.com
That's MISTER MODERATOR
Umm... the LT1 PCM requires the optispark to function. To use a rear installed distributor, you'll need to control the engine differently or go to a carb setup. LT1intake.com converts LT1 intakes to work on TPI-based engines.
The optispark, while a pain in the a$$, works well when in good condition.
The best thing you can do is convert to the LTCC system. http://www.bailey-eng.com/LTCC.html I'm glad I did...
1996, 350, carburated, coils, combo, conversion, convert, distributor, engine, hei, intake, lt1, optispark, projectlt10, swap
