turn key = NO POWER
Old 06-15-2007, 03:10 AM
InnocentZ28's Avatar
Default turn key = NO POWER
hey, i have a 97 lt1 and latley my car has had this problem when you turn the key on for all the eclectronics and fuel pump to come on and then turn the key to start the car, it just completely loses all elecronic power. but if you wait a min and let it cool the car starts up perfectly. anyone know what could cause me to loose all igintion when i turn the key on to start the car?
Old 06-15-2007, 05:40 AM
infinitebird's Avatar
could be ignition switch or vats.
Old 06-15-2007, 07:53 AM
94strokedz's Avatar
My guess would be ignition switch, mine did the same thing. Its on top of the column, and it costs about $30 if I remember right.
Old 06-15-2007, 02:36 PM
Pyro97's Avatar
you could try bypassing the VATS too, it's cheap and easy. This sounds like what my car did for a while. Does your security light come on?
Old 06-15-2007, 03:13 PM
94 ss's Avatar
my car did this same thing this week. i by passed the the vats and it started right up.
Old 06-15-2007, 04:20 PM
yea i replaced my ignition switch 2 days ago but i had already previously replaced it about 1 month ago and so i figured maybe i just got a bad one, but it still does it just not as often. Do you think that the ignition swith adjustment might have something to do with it?
Old 06-15-2007, 05:35 PM
SlowGreenTA's Avatar
Mine was doing this for a while. turned out to be a bad connection on the neg battery cable.
Old 06-15-2007, 06:34 PM
Cole Train's Avatar
^+2 i was just gonna say battery terminal. My buddies '04 Comp G GTP does the same thing if the negative get's loose or dirty.
Old 06-15-2007, 08:12 PM
Moderator
BizZzatch350's Avatar
If it looses electrical power its more than likley has to do with the battery system, be it a connection or cable. Vats, wont cause loss of electrical power, ignition switch shouldn't either. I have heard some weird things when ignition switches like gauges acting funny, but wont cause the car to loose all electrical power
Old 06-15-2007, 09:20 PM
Cole Train's Avatar
^ agreed. My '00 V6 Camaro had this and it was because i left the battery cable a little loose and it corroded. Be my guess. or a bad ground but i doubt that...
Old 06-16-2007, 10:30 AM
i went and checked all electrical connections and the only one looe was the one in the engine bay on the left side in that little red box. i pulled my starter down so i can replace it so hopefully one of these might fix it
Quick Reply: turn key = NO POWER
