OFF idles camshafts on LT1's
Hi everyone, i'm just thinking and i hope to found an answer! if we install one kind of sleeper cams (off idles) on LT1 so what's the results?? is it will worth?? any one have seen or tried same that kind of cams on LT1 application?
Thanks in advance
Thanks in advance
Guys.. you know all the off idles camshafts like CheatR, Stealth, GT2, Oldman ...etc so if we design one of same that cams on LT1's so how does it work?
How you guys didn't know what's off idles means??
This "off idles" term he's using is referring to a cam that will provide off idle torque. "StealthR," "Old Man Cam," etc. are street slang terms for a "sleeper" cam. (Cams that provide more power, but sound "stock.) In other words, a small cam.
The Crane 227 and Lingenfelter 211/219 cams are both proven performers. You might also look at the new Lunati "Voodoo" #60120.
Originally Posted by speed_demon24
Old man cam and Steath cams are the actual names of the camshafts, thunder racing sells them.
Originally Posted by seawolf06
Still lost...
speed_demon24 and thesoundandthefury, Why i can't use the same LS1 lobes on LT1 cams (off idles lobes)??
Huh.. i think i got the answer.
What's the specs of Cadillac cam??
thesoundandthefury. you're right, but we would like to see a results for someone have tried any LS1's off idle cam specs on LT1 ??
