Pros and Cons of the heated O2 sensors
Old 06-25-2007, 03:54 PM
litch2004's Avatar
Default Pros and Cons of the heated O2 sensors
Well i had the conversion diagram to turn my O2 sensors in my 93 T/A to the newer style. And like the title says what are the pros and cons of the two? Besides being able to run a different type of air/fuel ratio
Old 06-25-2007, 04:16 PM
litch2004's Avatar
anyone????
Old 06-25-2007, 04:20 PM
Formula350's Avatar
Ccchiiillllll You only waited 22mins
Old 06-25-2007, 04:47 PM
litch2004's Avatar
sorry got a little sidetracked didnt pay attention to time
Old 06-25-2007, 05:09 PM
hashtagBMW
Speed Density's Avatar
I see nothing but Pro's to doing the heated swap.
You run a more advanced O2 as well as them being heated so your ECU gets the correct readings.
I would only do it if you plan on getting Longtubes in the near future.
Tony.
Old 06-25-2007, 07:52 PM
litch2004's Avatar
From what i have seen you are only able to plug in the low res. signal and not both the high and the low res. signal.
Old 06-26-2007, 08:54 AM
litch2004's Avatar
anyone else ?
Old 06-26-2007, 10:32 AM
Fastbird93's Avatar
Check out speeddensity.org and ask the guys there. I did a wiring harness kit up for most of the guys there running them and there's been ZERO issues (myself included). The Low res signal is the one that's used, the high res is a redundant signal. You'll be fine.
Old 06-26-2007, 05:53 PM
litch2004's Avatar
that is what i had figured but i figured i would ask and see if anyone out there had done it and if there were any problems.
I also just read an article about people changing from their MAP sensor and going over to MAF sensors. This was on a different car but same principle. They were saying that the potential is there for more tuning and better performance. Anyone heard of this or has attempted it?
Old 06-26-2007, 10:49 PM
Fastbird93's Avatar
Blah, stick with the SD. It's just easier to tune the MAF cars because of no chip and the MAF tables. SD tuning gets a more accurate tune and there's one less component to fail.
Quick Reply: Pros and Cons of the heated O2 sensors
