LT1 upgrade
Old 06-25-2007, 11:04 PM
Camaro9495's Avatar
Default LT1 upgrade
I currently have a 94 Camaro with a 3.4L engine. I've always wanted a Z28 or SS that was a 4th gen. I was offered a short block LT1 for $200. It has about 90K on it. I was wondering if it would be a good idea to buy it and make a high performance engine out of it. I'm looking to get maby 450-500 horses from it without nitrous or turbo's/superchargers. I've herd some disaster stories about people trying to swap engines from their 4th gen camaros. All the work would also be done in my 2 car garage, so theres not a lot of room there. I also dont have a lift. I've been reading some of the posts about people doing engine swaps, but i havent really read much about people swapping a V6 for a V8. This project would also not be an over night swap, it would probibly be a 1 year project. I was curious to see what your opinions are on it.
Old 06-25-2007, 11:06 PM
doaberetta's Avatar
my car is broke right now.
94 firebird with 96 ss lt1 motor and pcm in it now.
get out your shoehorn. (expecially with the t56)
Old 06-26-2007, 02:17 AM
LT1
LT1's Avatar
it might be actually cheaper to go out and by a LT1 f-body instead of doing the swap, youll end up spending the same amount in parts, unless your able to get a donor car with what you need.
Old 06-26-2007, 03:48 AM
BLK,97,T/A,M-6's Avatar
Dont even waste your time on the swap. Go out and find the car you want. SS WS-6, Whatever. The engine swap is a bad idea for many reasons., the least being, that the struts and springs should be exchanged to deal with the extra weight... Wiring. lsd in the rear vs the open diff in the v-6. You wont be happy with just the engine swap.
Old 06-26-2007, 04:16 AM
Formula350's Avatar
Yep, you'll want a donor car.
Old 06-26-2007, 07:06 AM
daniel6718's Avatar
just sell yours for like 2000 and keep your eye out for a f-0body with broken dash and interrior needing work and paint...ive found several that just needed 200 bux worth of interrior that sold for 2500-3000 bux i resold for 4k
Old 06-26-2007, 07:36 AM
Formula350's Avatar
And don't let higher miles scare you on an LT1. 90K on an LT1 is like 60K on other cars
Quick Reply: LT1 upgrade
