What are these things? (Pictures)
Obviously, the pictures say it all... what are they, and why are they in the condition that they are? Incase you're wondering, the first are of a module (looks like relays) under the glovebox panel... not sure why certain wires are spliced together and some are just left hanging. Any input? Also, that vacuum line is coming out of the fuel line bundle and is supposed to connect just below the throttle body, but there's no suction in the line with the car running... so I don't know what the purpose is. Someone enlighten me!
http://img152.imageshack.us/img152/3311/1010329mm7.jpg
http://img150.imageshack.us/img150/6301/1010331aw8.jpg
http://img295.imageshack.us/img295/2713/1010332ki3.jpg
http://img150.imageshack.us/img150/8109/1010333bf8.jpg
http://img227.imageshack.us/img227/4590/1010334el3.jpg
http://img292.imageshack.us/img292/804/1010335qo3.jpg
for bigger pictures, thanks!
Ok I will take a shot. It looks like the fuses could possibly have went to a nitrous kit? I think the extra line your referring to is the evap line coming from back of car. I believe that it should rap around to the solenoid on the passenger side of the intake manifold.
Yeah that's the evap line for the fuel system also known as charcoal canister purge. Personally, I deleted mine. I also turned off the function with LT1 Edit. I wouldn't recommend just yanking it off. What looks like you have under the dash is a set of aftermarket relays. Someone has had something hooked up, nitrous like it was mentioned or maybe a car alarm.
Originally Posted by LEVID
What needs to be done to delete the evap line and all that... I accidentally broke the piece that it runs to the other day
