LT1 gas tach is dying
sounds like the in tank float is stuck, or the sending unit is bad. bang on the tank a little, or push the back of the car up and down, and back and forth. these sound stupid, but worked for me before. Also the only GAUGE called a tach is the Tachometer, which displays engine rpm. The rest are simply called gauges IE gas GAUGE
Yea, he's quick, we all know this lol
Also, GM gauges SUCK. Well, the senders do, maybe it's the gauge, I don't know. They are fine till about 1/2 tank, when the gauge just DROPS down to E. Every GM I've own is like this too (2 Suburbans, 1 Park Ave, 2 Firebirds). I ran out of gas this weekend
im on half right now imma fill her up tomorrow for my drug test lol o yea i got a job. go ahead congradulate me lol.
Should shake the car now to make sure its on the right setting cause earlier today i had that thing that comes before F.
take some hard corners and a few hard stops. I have had mine stuck 1 time and after some spirited driving it gave in and went back to its old ways. ( It happened after my car had been under 1/2 a tank for along time, and then I filled up)
J/p..
I figured out the other day that I have left a little under 1/4 tank in the Camaro, it's been sitting for about 4 months. I'm goin to put some Dry Gas in it, and fill it up with fresh Gas so it mixes up. That should work. If not, some Everclear will spice it up..
It's a sending unit, you goto the parts store, that's what they're there for. Or in your case, take it to a shop since it involves more labor intensive work that changing your injectors (AKA spark plugs )
