pcv valve
pcv valve
i just took mine out to see what it looked like and i found some gunk on the end and in the tube is there any way to flush out the metal line im not sure what it lookes like in there but i suspect the same by the way the plastic line is gunked wont the idle be off a little if the pcv valve dosnt colse all the way? i can blow back threw it i even sprayed in it with some stp and it wont shut all the way
