Is my opti-spark broken?
Old 07-03-2007, 12:50 AM
Built LT1's Avatar
Default Is my opti-spark broken?
After making numerous useless attempts to get my new motor started, I pulled the opti and noticed that it did not spin in perfect circle, it spun in larger circles, much like a rotary engine. Is this normal?
I also noticed around the spline that the spring holding a rubber grommet on the shaft was not on correctly. I looked into the timing cover hole and saw a similar spring lodged in there as well.
Do I need a new opti? I can remove the spring with tweezers, but should I remove the cover as well to be sure of any other possible debris?
Old 07-03-2007, 02:00 PM
Nine Finger 02 Z28's Avatar
Bump on this any help???
Old 07-03-2007, 02:30 PM
383 trans am guy's Avatar
if your gonna replace the opti spark get a dyna spark brand its worth the money look it up online itll be the last distributor youll ever buy
Old 07-04-2007, 04:45 AM
Built LT1's Avatar
Thanks.
Old 07-04-2007, 05:22 AM
Formula350's Avatar
Or get a remy Opti and do the EDIS Coil Pack conversion.
http://brian-esser.com/?page_id=24
Old 07-04-2007, 08:35 PM
robby73z28's Avatar
get an accel opti did wonders for my ride
Old 07-04-2007, 08:46 PM
Sharpe's Avatar
Poo on the Optispark.
That is all.
Quick Reply: Is my opti-spark broken?
