Water pump leak?
Water pump leak?
I was driving the other day and I noticed that the temp gauge was maxed out and i had no coolant in the radiator. I just recently did a tb bypass and i thought that might be the problem, so i redid the connection and made sure all the bolts on the water pump were tightened. I started up the car and it didnt leak until the thermostat opened up. Coolant was leaking down the front of the engine at a constant drip. I think it might be the water pump gasket but im not sure. All suggestions are appreciated.
Theres 135,000 miles on it, but the guy i got it from had replaced it shortly before i got it 6 months ago...I just looks like its leaking down the front of the engine, but i only see water from bottom up to the where the water pump connects to the block. if its leaking out of the weap hole what does that mean??
